3100 3400 3500 performance!
Old Jan 28, 2010 | 05:14 PM
bob442's Avatar
Default 3100 3400 3500 performance!
just thought i would promote this site for us 60dv6 3x00 guys
check it out, performance cams, heads, throttle bodys, headers, Intake manifolds, swap parts, valves, everything, plus an awesome tech forum.
http://wot-tech.com/shop/
www.60degreev6.com
Old Jan 28, 2010 | 05:24 PM
man, you won't believe this, I saw this before and saved it to my favorites and was recently looking for it but I couldn't find where it was! thanks for the info!
Old Jan 28, 2010 | 05:37 PM
bob442's Avatar
NP man, this guy should get alot of recognition for all that has has got and done. i'd like this to be posted up as a sticky, because alot of guys dont know theres performance parts out there for there 60dv6 to push them to 250 hp, but instead want to swap a 3800
Old Jan 28, 2010 | 05:40 PM
shingding88's Avatar
ben from wot-tech is friggin awesome. i have bought roughly $1000 worth of parts from him and they are flawless i second the fact that he should be recognized
Old Jan 28, 2010 | 05:41 PM
I remember now, shingding88 you were the one who posted this before, thanks to both of you!!
Old Jan 28, 2010 | 07:00 PM
bob442's Avatar
Old Jan 28, 2010 | 07:11 PM
what do either of you know about HP tuners, explain this credit thing and credits per year/car? I have absolutely no clue, and what could it do for a pretty much stock 3.9 2006 monte? the only mod I have is a CAI, might add a better sounding exhaust but that is about all for my monte, thanks
Old Jan 28, 2010 | 07:16 PM
HPTuners is software for a laptop. You run it, and plug your car into the OBDII port under your dash.
Every car has its own VIN#, so HPTuners makes you buy credits for each VIN you want to tune. Once you buy the VIN you can edit that car as much as you want.
You get 8 credits. You can buy just your car for 2 credits, or you can buy every Monte that is your year for more credits.
On a stock car, you can do a few changes, but tuning is a very difficult thing to do. Requires a lot of reading and knowing what to do.
Old Jan 28, 2010 | 07:19 PM
bob442's Avatar
-there is some stuff i believe, but i'm not sure, poke around on www.60degreev6.com
-Credits are use of tuning abilitys per PCM as everytime the tuner is pluged in, it reads that it is an a different (incripted) PCM, so you can only tune 1 PCM per Credit
-You could change shift points, rpm limits, speed limits, fool around with A/F ratios, you can change spark curves, fuel curves, possibly make more power, but wouldnt be worth it with out a few more minor mods.
Old Jan 28, 2010 | 07:29 PM
thank you Mike and Bob, for all the info, you would think after all the time I've been on here I would have figured that out already! it goes to show that you learn new things all the time, thanks
