3.8 series 1 to series 2
Old Apr 21, 2010 | 09:22 PM
nebstewart07's Avatar
Default 3.8 series 1 to series 2
Is it possible to swap a 3.8 series 1 to a series 2 3.8?
Old Apr 21, 2010 | 09:52 PM
Yes, what kind of car is it in?
I'd imagine you'd need the complete powertrain, engine bay wiring harness, and pcm. Not sure how much the engine and trans mounts changed...
Old Apr 21, 2010 | 10:42 PM
Actually my monte has a 3.4 liter in it. The car I would be swapping would be a 1995 Buick riviera with a 3800 series 1 with a motor form a 97 buick rivier 3.8 series 2
Old Apr 22, 2010 | 08:22 AM
MAMONTE's Avatar
I would imagine that, yes, you could make the swap. I would think you definitely need the pcm, wiring harness, etc.
Old Apr 22, 2010 | 11:43 AM
K-Mac Attack's Avatar
The long block should be the same. I would use the PCM from the 95 as it is going to be OBDI and the 97 will be OBDII. That could be a pain to deal with.
Old Apr 22, 2010 | 08:56 PM
SI and SII bottom ends are not the same for sure.
Also, if you switched over the engine bay wiring, I'd make the changes to the obd port inside too- I'd way rather have an obd2 pcm for tuning options later.
Denarius23
Sep 17, 2014 02:18 AM
golfstud2k4
Sep 29, 2010 03:37 PM
BlueEssEss
Jun 1, 2006 04:54 AM
jet404
Aug 14, 2005 03:26 AM
04MonteLS
Jun 3, 2005 06:07 PM
