3.8 series 1 to series 2
The long block should be the same. I would use the PCM from the 95 as it is going to be OBDI and the 97 will be OBDII. That could be a pain to deal with.
Also, if you switched over the engine bay wiring, I'd make the changes to the obd port inside too- I'd way rather have an obd2 pcm for tuning options later.
Denarius23
Sep 17, 2014 02:18 AM
golfstud2k4
Sep 29, 2010 03:37 PM
jet404
Aug 14, 2005 03:26 AM
