3.8 Liter V-6 Coolant Elbows
Old Sep 24, 2010 | 08:41 PM
jcoeracing97's Avatar
Exclamation 3.8 Liter V-6 Coolant Elbows
Just in case anyone needs a little advice on changing upper/lower coolant elbows, be careful when removing the belt tensioner bracket due to pieces of the old coolant elbows coming apart at the o-rings inside the coolant passages. It's not a big deal if they do, just ensure that you take time to remove all debris from the passages and throughly clean these areas prior to the reinstallation process. Also, I had been told that these items were "dealer only" yet they may be purchased at most part stores under the Dorman brand for as little as $3.99 a pair. Just a little free advice...
Johnboyp92
Apr 5, 2013 11:27 PM
iMSeRiOuS
23
Dec 23, 2012 08:48 PM
Budsjlm
23
Nov 11, 2012 06:07 PM
muleys99
May 2, 2012 08:40 PM
adoublearonn
May 2, 2012 02:29 AM
