3.1 Knock
Old Dec 31, 2011 | 12:15 AM
nitehawkjcb's Avatar
Whoa that's loud as ****
Mine wasn't ever that bad, but it did sound the same... just not so bleeding loud.
Old Dec 31, 2011 | 08:52 AM
Sounds like the engine makes that sound through the entire video.... My first thought:
- How many miles are on it?
Followed with, it runs fine, just has that noise, try the remedy that worked on my wife's 3100 Grand Am, throw in a bottle of motor honey or Rislone. See if that changes things after a day of driving.
Old Dec 31, 2011 | 09:02 AM
The noise does quiet up alot once the engine is warm. Mileage is roughly 143k and yes i still have to try a bottle of motor honey and see what happens.
Old Jan 1, 2012 | 06:03 PM
1996Monte_Carlo's Avatar
i found that running royal purple actuallly quieted my noice on a cold start up
Old Jan 1, 2012 | 06:27 PM
tps221's Avatar
holy crap thats loud mine takes like 30 sec of driving and stops and it not that loud and has 156800 on all origninal motor
Old Jan 1, 2012 | 09:50 PM
Budsjlm's Avatar
You didn't let it get up to operating temp!
But yeah the guy in the first vid is full of it, lifter tick is normal not piston slap,
Yours sounds more like piston slap, if you let it warm up everytime you drive it it should last some time
When we where looking for a car I want to test drive a 5th gen the chick tried to give me the line it ticks but the mechanic I brought it to says it's normal, when we got there to test drive it she was running to the store in it, took it for a test drive and the piston slap was so bad when you would stick it in first, bring the RPM's and let off ( engine braking) you could hear it slapping
Old Jan 1, 2012 | 09:55 PM
Dont know what to make of it honestly. Hopefully the end isn't near...
Old Jan 1, 2012 | 11:14 PM
Just keep your maintenance up on it, I'm sure a new shortblock is dirt cheap for that engine anyways.
Old Feb 4, 2013 | 04:14 PM
ucantseeme702's Avatar
Default please help!
i have a 1997 chevy monte carlo recently i redid the heads cause it was over heating.i put it back together started it up and it was ticking alittle drove around block tick got louder then oil light came on.took off valve covers only little oil getting to rockers so i replaced oil pump and screen still no change and the knock is really loud now.and i know its cause no oil pressure.the engine only has 120,000 on it could the rod bearings be gone already?thankyou
Old Feb 4, 2013 | 06:44 PM
tps221's Avatar
get help from a pro
