2004 Water Pump replacement.
Hey everyone, I just recently found out that I need to replace the water pump on a 2004. I have very little knowledge about these cars so any help would be greatly appreciated. I do know a fair amout about cars, but mostly imports.
I am really looking for a good how-to on this so that I can avoid paying the shop again to do any work on this car.
Thanks in advance everyone.
The easy way to know what your engine is is by the model. For 2004, there is either the LS (3400 v6), SS (3800 v6), or the Supercharged SS (s/c 3800 v6).
Whichever it is, the job is pretty straightforward.
I wanted to thank you guys for the links, I did the replacement the other night and it went perfectly. I had to do a little more research to figure out how to loosen the belt tension, and where the radiator drain plug was. But other than that it was the easiest job i've done on a car in a long time.
pilotknob1964
10-03-2009 01:53 PM
sportjunkee
01-13-2008 07:13 PM
