6th Gen ('00-'05): 2002 3.4ls transmission change
Old Nov 24, 2023 | 01:07 PM
jadendavis's Avatar
Default 2002 3.4ls transmission change
I have a used trans to swap out my blown trans, i have normal jacks and stands and was wondering where to jack up the car for the transmission change if the pinch welds arent solid
Old Nov 24, 2023 | 01:49 PM
Assuming you're pulling it out the top, you could always just jack it up using the engine cradle / put thr stands under the cradle also.
Old Nov 25, 2023 | 03:21 PM
Jeffs02rwdSS's Avatar
Pinch welds being bad are a common issue. About 1 ft further under the car is what looks like frame rails. That would be the safest place to jack up and put strands underneath. For the back you might need to use your best judgement. Perhaps car ramps might be the best answer.
Dakota J Mellors
Feb 5, 2021 09:26 PM
owen231
Jun 9, 2014 01:25 PM
vikesfan
13
Oct 23, 2012 08:15 AM
mwjames
Feb 28, 2012 05:41 PM
