200 vs. 700 ???
Old Oct 29, 2009 | 07:19 PM
aw9d's Avatar
Default 200 vs. 700 ???
Hey everyone,
I have a 1985 SS, 305v8. I am going to pull the stock motor and put in a new 350. I have read that these SS's had 2 transmissions, a 200 and 700 version. I read that if you look at the transmission pan you could figure out what version you had. The 700 is a rectangle where the 200 has a corner cut out of its shape. Has anyone heard anything like this?
Thanks!
Old Oct 29, 2009 | 07:27 PM
Budsjlm's Avatar
yes i have i will get a link for you it will show you all different ones ...but it may take a while ( i post with my phone)
Old Oct 29, 2009 | 07:32 PM
The Popcorn King's Avatar
Here is the info you need man.
http://gbodyforum.com/viewtopic.php?p=10826
Hope this helps man.
Old Oct 29, 2009 | 08:09 PM
Budsjlm's Avatar
man jj you are good.. well since i got one too i'll share it
http://monte-list.nu/tech/trannyid.shtml
Old Oct 29, 2009 | 08:15 PM
sideways's Avatar
If it's an 85 SS it had a 200-4r from the factory. That was the only trans avaliable in an SS. No 700-r4 's in any G-body factory.
Old Oct 29, 2009 | 08:33 PM
RocknSS04's Avatar
GREAT info guys!
Old Oct 30, 2009 | 07:18 AM
drewskie043's Avatar
i would stick with the 200R4. then you don't have to deal with relocating your trans crossmember and changing your drive shaft length. i would take it to a shop and get it rebuilt so it's reliable for years to come. you can build them to withstand almost any engine, i've even seen them behind a 454 with about 475+ hp. then all you have to do is drop it back into place and bolt it up, not cutting or modifying.
Old Oct 30, 2009 | 03:55 PM
sideways's Avatar
What he said^^. I need to get another one put together for my elcamino, cant complain broke it at the track in July. Was rebuilt back in 92', had 183,000 on it then added another 40,000 or so since + 488 passes down the track(slips I can find, maybe more). Locked up between 3rd and 4th at 105-6mph.
Will probably cost alittle more for the 200, but the gear spread is alot better.
Attached Thumbnails 200 vs. 700 ???-bell.jpg   200 vs. 700 ???-dsc00528.jpg   200 vs. 700 ???-dsc00523.jpg
Old Oct 30, 2009 | 04:00 PM
Budsjlm's Avatar
i'll be selling the trans outa my 85 as soon as i pull it out
Old Oct 30, 2009 | 04:41 PM
TheMonteMan's Avatar
they make a different planetary gear set for the 700 as well, but its 900 bucks. if you do go for one they come in i believe 27 and 30 spline. nice bellhousing pic you are not alone with that. mine broke on the street though. suspected culprit was bad angle.
