01 SS Shaking Terribly
Old Sep 2, 2009 | 04:49 PM
xman23's Avatar
Question 01 SS Shaking Terribly
Hi all,
My monte is shaking under acceleration and idiling very low while in park and at stop lights (almost stalls). It smells horrible. Sulfur and ammonia combined. It barely makes it up hills and shakes immensely when doing so. I can reach the speeds I need to but it takes a while to get there and it feels like the engine is going to blow.
My check engine light begins to flash when accelerating.
I have changed the following the last 2 days:
I changed these things because of the above mentioned (None of these repairs worked)
Catalytic Converter
Plugs
Plug wires
Fuel Filter
Anyone have any ideas?
Thanks for your time
Old Sep 2, 2009 | 04:59 PM
Hi Xman, I feel your pain $$ 4-Sure. Check back on your post & hopefully one of expert tech will have a suggestion for you.,..Until then check out my search results...Good Luck
ACDelco | Auto Service & Car Maintenance | Troubleshooting
Noises, smells & leaks are all signs that something could be wrong with your vehicle. ... Detonation, Mild to severe ping, usually worse under acceleration and load. ... Car may also shake. Sluggish, Engine delivers limited power under load or at high ... Continuous, heavy sulfur odor, like rotten eggs, Emissions ...
www.acdelco.com/service/troubleshooting.jsp - Cached - Similar
WikiAnswers - Car Shaking Problems Questions including "How do you ...
What would cause a car to shake and sputter and lose power only under heavy .... Why does your car shake during idle and acceleration? .... Why would white smoke a gas smell and shaking of a vehicle occur all at the same time? ...
wiki.answers.com/Q/FAQ/482 - Cached - Similar
Car-Trouble.com : Symptoms : Free automotive diagnosis & forum.
Poor acceleration is felt as a lack of power when accelerating, resulting in a slow rise ... steering wheel, shifter, pedals, or anywhere else in the car as a very fast shaking. ... Fuel smell; Rotten Eggs smell; Sulfur smell; Oil smell ...
www.car-trouble.com/symptoms.html - Cached - Similar
VWvortex Forums: car shakes under acceleration (occassionally)
Apr 11, 2008 ... I have noticed that it shakes under moderate to heavy acceleration. As I let off the gas the shaking goes away. ...
forums.vwvortex.com/zerothread?cmd=print&id... - Cached - Similar
>troubleshooting
Noises, smells, leaks and operating changes are all signs that something could be wrong with ... Mild to severe ping, usually worse under acceleration and load. ... Car may also shake. Sluggish. Engine delivers limited power under load or at high speed. ... Continuous, heavy sulfur odor, like rotten eggs. Emissions ...
www.spitfireauto.com/id12.html - Cached - Similar
Car Shakes While Driving Questions
Car Shakes While Driving Questions Information Got a Car Repair Question? ... The vibration causes the passenger seat to shake a little, and I can feel it under my feet. ... The faster the acceleration, the more noticeable the shake! ...
www.2carpros.com/topics/shakes1.htm - Cached - Similar
Old Sep 3, 2009 | 11:46 AM
xman23's Avatar
Could it be the coil packs or ignition coil? I checked all 6 plugs and none of them were cracked.
Thanks for the reply KidSpace
Old Sep 4, 2009 | 09:57 AM
xman23's Avatar
Problem found.
Took it to a local shop and found the following problems:
1. Ingnition Coil Bad - Not sure which one, so I will replace them all
2. #3 Fuel Injector Bad
I will post back next week when I make the repairs.
Shop wanted to charge me $600 for parts and labor and perform a fuel injection clean with the BG kit for $119.
I will be able to do everything in my driveway for $160
Old Sep 4, 2009 | 10:00 AM
Remember to lubricate the O-Rings on the Injectors when you put them back in so you don't tear one.
Old Sep 4, 2009 | 03:57 PM
xman23's Avatar
thanks chibiblacksheep.
I will be sure to do that. You recommend a certain lubricant?
Old Sep 4, 2009 | 05:25 PM
dielectric grease.
Not much, but just put some on with you finger so it doesn't tear.
Old Sep 10, 2009 | 07:30 AM
xman23's Avatar
Replaced all 3 Coil Packs last night and no more shaking, no more flashing check engine light, and it drives a lot smoother. Car is idling very nice.
However, I am still experiencing a sluggish response when I accelerate rapidly and on the top end. (A minor popping condition in the exhaust) It acts like it is hesitating. It almost feels like one of the cylinders is still missing.
Drives great under normal acceleration.
I am going to replace the #3 fuel injector tomorrow and see if that resolves the issue.
Old Sep 10, 2009 | 08:23 AM
It does sound like it could be a fueling issue, but out of curiosity how does your air filter look?
Old Sep 10, 2009 | 11:17 AM
drewskie043's Avatar
for future reference, whenever your check engine light flashes, it means there is a major cylinder misfire.
