01 monte ss rough idle and knock
I. Started my car this morning and the idle was rough and the motor was ticking or knocking or something. I have a video I took with my phone to show but dont know how to add it on here. I need some help please...
mines do that too sometimes in the morning with cold starts, i think it was called piston slap which is normal for these motors, once warmed up it goes away. you could also check for codes just to make sure everything is ok
Whens the last time you did an oil and filter change on the motor?
Is it low on oil? I would also add some Lucas high mileage motor treatment when you do an oil/filter change!
What motor is in this car and how many miles are on it?
That definitely sounds like a lifter ticking...
ahhh i forgot about that as well...mines made that similar noise when i was having the oil problem too
It just maybe dumping antifreeze into the motor as well.... pull the dip stick and smell it...Does it smell like gasoline?
You may just have something serious going on inside the motor....
Generally 3800's do not sound like that.
Maybe its time for upper and lower intake gasket repair?
Have the uim and lim ever been changed ????
3800's are known for there intake failures both upper and lower..so you might as well change both since you'll have it apart anyway.
Are you loseing/Using antifreeze?
Its worse when you first start it. The rough idle and the knocking. Then when it gets up to operating temp it seems to go away. After what my dad read we added some marvel mystery oil to it. To free sticky lifters.
