01 monte no power/get up and go
Old Oct 23, 2012 | 01:22 PM
61brown61's Avatar
Default 01 monte no power/get up and go
I have an 01 monte ss 3.8 with 150k on it. In the last week or so lost power as in you floor and it will increase in rpms but won't go for a few seconds then takes off but not as fast as it used to. I check fuel pressure it was 10 psi, replaced fuel filter got me to 30 psi. Then the pressure regulator went out and replaced that. Was only at 40 psi after that. So I put a new fuel pump in and now I'm back in the 80-90 range. But still has no power. Has better then it had but still not the same as it used to. Also did a cylinder balance test and each cylinder dropped the idle around 200 rpm each. No dtcs or anything except traction control and abs because the left from Hub sensor is out. No rotten eggs smell either. Any suggestions? Also checked plugs and they looked fine, cleaned throttle body and idle air control
Old Oct 23, 2012 | 01:36 PM
Just because you don't smell the rotten egg, doesn't mean it isn't the cat. You should get it back pressure tested.
Old Oct 23, 2012 | 02:58 PM
I would say it's just because it's a Monte Carlo... but if you're even SLOWER than usual I agree with Mike, I would look into getting the pressure tested lol
Old Oct 23, 2012 | 02:59 PM
01 Monte SS's Avatar
We need pictures.. maybe it's the appearance causing it to be slow?
Old Oct 23, 2012 | 03:35 PM
YelloJac's Avatar
From: Garfield, New Jersey. But my Home will always be The Bronx
Also check your Trans fluid. If it is low or burned it can cause a loss in power due to slippage on take off or left turns.
Old Oct 23, 2012 | 06:00 PM
He would definitely feel and hear errors with the trans though if that was the case, you would think at least
Old Oct 23, 2012 | 07:14 PM
YelloJac's Avatar
Definitely feel and hear a Hard Clunk! In 1st and 2nd gear!
Old Oct 24, 2012 | 02:59 AM
61brown61's Avatar
Any way I can chek the cat without taking it to a shop to do the pressure test?
Old Oct 24, 2012 | 08:10 AM
Drive it hard at night and then look underneath and see if it's glowing red, or take some temperature readings before and after the cat and see if there's a huge change
MonteCarloLover#1
Jun 19, 2013 10:03 PM
chevymontess
Sep 13, 2011 10:00 PM
Pure2sin
Jun 11, 2011 02:32 PM
tbmaniacal
Nov 29, 2010 02:09 AM
