Top swap question
Old Sep 2, 2010 | 10:00 PM
Enzo354's Avatar
STILL SLOW
Im going 3.8 pulley, but ill have headers, res delete, 104s, 180 tstat, tune, FWI, and ported heads lim and sc, so I should be good
Old Sep 2, 2010 | 10:10 PM
nitehawkjcb's Avatar
Oh yeah, ported heads will do wonders. Killed 8* of KR for me.
Old Sep 2, 2010 | 11:00 PM
Enzo354's Avatar
STILL SLOW
Well theyre intake gasket matched and i smoothed down a few tiny things so its not ridiculous.
Old Sep 2, 2010 | 11:41 PM
DarkSS's Avatar
Good luck with the swap. I'm starting mine next weekend.
Old Sep 3, 2010 | 05:10 PM
03SS/00GSE/93LX's Avatar
Man... You're Monte is going to be SO different when you're done. Trust me.
If you have the budget at all, I'd really recommend throwing a set of 1.9 rockers into it while you've got it torn apart- they'll really let you maximize you're setup with that 3.8 pulley. An L36 bottom end on a 3.8 pulley with full supporting mods and 20-22* of WOT timing is pretty damn quick!
Old Sep 4, 2010 | 02:35 AM
Enzo354's Avatar
STILL SLOW
I was totally gonna go xp but ran short of funding, and rockers will come eventually, I just need to buy other more important things, like a gauge pod
Old Sep 19, 2010 | 11:52 PM
Pure2sin's Avatar
What was the end result of your top swap? I am starting to hear bad things about tuning on L36 PCMs on 00-02 Montes.
Old Sep 20, 2010 | 08:14 AM
Like what, Pure2sin? The 00-02 PCM is about the same as my 03 PCM. I'm still running my L36 PCM, tuned quite a bit obviously, with no issues.
Old Sep 20, 2010 | 04:01 PM
Pure2sin's Avatar
What bin file did you use? Cause you can't just use the 2002 L36 bin file cause it won't work.
Old Sep 20, 2010 | 07:55 PM
Pure2sin's Avatar
Bump^^^^
