3.8L questions
Old Jun 19, 2011 | 06:35 PM
garshev's Avatar
Default 3.8L questions
My Wife's 2003 Monte SS is having some issues. It has 66M miles and has been pampered. It severely is lacking in power and at 4000 rpms it acts like it is against the rev limiter. It starts missing and will not spin any faster. What's everybody's best guess?????
Old Jun 19, 2011 | 07:18 PM
Clogged catalytic converter.
Old Jun 19, 2011 | 07:38 PM
zipper's Avatar
^This
Old Jun 19, 2011 | 09:23 PM
I vote cat.
Old Jun 20, 2011 | 02:37 PM
garshev's Avatar
It was the catalytic converter. $747 for the part + 94 labor to install. Replacing the left rear hub bearing to get rid of the abs light that has been on for years. Damn, expensive to drive these things anymore.
Old Jun 20, 2011 | 02:50 PM
That's a shame, it could be done for so much cheaper if you went aftermarket.
Old Jun 20, 2011 | 03:27 PM
garshev's Avatar
They told me the aftermarket piece would cause engine codes. I went with the oem and probably got greased.
Old Jun 20, 2011 | 03:29 PM
As long as it's fixed
Old Jun 20, 2011 | 07:02 PM
zipper's Avatar
Anyway you can get a refund and just get this cat instead: ZZ Performance
That cat won't throw codes, and ZZP ships out the same day (I usually get parts from ZZP the day after I order them). $60 is a lot better then $747. That shop hosed you sadly.
Old Jun 20, 2011 | 08:53 PM
Thanks for the tip Zipper. If my cat ever goes bad in my 03 this sounds like a good replacement. I don't want to put a down pipe on the 03 cause I don't want to reflash my pcm.
