windows
Old May 20, 2007 | 12:38 PM
mcarloss04's Avatar
Default windows
I had my windows replaced for my 04 ss because of discoloring of the windows. And now I am noticing the color again any suggestions? Could it be from the water? I use window cleaner that is amonia free.
Old May 20, 2007 | 03:43 PM
wiz kidd's Avatar
Default RE: windows
is the discoloration on the outside of the windows or the inside ?
Old May 20, 2007 | 06:42 PM
mcarloss04's Avatar
Default RE: windows
outside
Old May 20, 2007 | 08:00 PM
FlynhghR's Avatar
Default RE: windows
On the glass I wouldn't worry about it, just don't use anything with ammonia or alcohol on plastic. What are you useing to wipe it down?What color is it turning?
Try stoners Invisible glass. I use this on all my glass and it does a great job, bettter than any cleaner I've ever used.
Old May 20, 2007 | 08:31 PM
wiz kidd's Avatar
Default RE: windows
do you live in an industrial area?? maybe its just something in the air there
Old May 20, 2007 | 08:57 PM
mcarloss04's Avatar
Default RE: windows
no i use just non amonia glass cleaner. The color looks like an oily color it happened to all of my windows before but not its my front and back only. If its just water spots whats the best way to get them off
Old May 21, 2007 | 10:10 AM
wiz kidd's Avatar
Default RE: windows
windex is great...and i use kleenflo glass cleaner on mine...i haven't had any problems..never heard of that hapening yet
Old May 21, 2007 | 10:50 PM
FlynhghR's Avatar
Default RE: windows
If it's water spots it's likely actually etched into the surface of the glass. Use some kind of glass wax to protect it is about all you can do. Removing it means polishing the glass which is a serious pain. Get a cheap cover, just something to cover the car if it sits outside. Sprinkler systems can leave hard water deposits on the paint, and the glass, eventually etching it.
Old May 22, 2007 | 07:15 AM
mcarloss04's Avatar
Default RE: windows
i used real fine steel wool and it came right off thanks guys
Old May 22, 2007 | 12:15 PM
wiz kidd's Avatar
Default RE: windows
its gotta be something in the air or water where you are then, because its coating your car in it...is it doing the same thing on the paint?
