Where Can I get this Grill
Old 07-26-2005 | 06:16 PM
Ca$$e's Avatar
Default Where Can I get this Grill
http://www.kevnascar.com/monte/pictures/2003monte2.jpg
copy and paste link, b/c I cannot wrap url codes around it while Im at work.
Old 07-26-2005 | 09:21 PM
RiFrechSS's Avatar
Default RE: Where Can I get this Grill
That's an SLP grille, but SLP online don't list it... You have to call them to order it.
I have the grille that's on the Tony Stewart Signature Edition cars...
I got it from GMPartsdirect.com but, you'll need the part number to order from them.
That number is #15236535 They come without any bowtie emblem or anything on them...
I added a bowtie that comes from the trunklid to mine...
Old 07-27-2005 | 12:04 AM
montejass's Avatar
No wonder I could not find that sucker. I knew it was SLP but thought it was a discontinued item. Do you know what they cost?
Old 07-27-2005 | 12:35 AM
RiFrechSS's Avatar
ORIGINAL: montejass
I believe I saw someone on another board say it was $129.?? or close to that price plus shipping, but not sure.
The GMPartsdirect.com T. Stewart grille was 115.?? shipped
Old 07-27-2005 | 02:04 PM
Ca$$e's Avatar
ORIGINAL: RiFrechSS
The reason why I want this is b/c I saw it on the Tony Stewart Model then I found the SLP one. Im probably gonna go with the Tony Stewart one though, Thanks bro.. btw Was it hard to install?
Old 07-27-2005 | 11:54 PM
RiFrechSS's Avatar
ORIGINAL: Ca$$e
ORIGINAL: RiFrechSS
No not hard at all to install...If you have ever put on a set of VentVisiors, it goes on the same way, 3M 2 sided tape
that's on the back of the grille..
First you need to remove the monte crest... It is on with the 2 sided tape, so you have pry it off...
Then after it's removed, I took some 3M adhesive remover to get all the leftover adhesive off..
I then used blackout tape (Pep Boys sells it) so my blue color on the front didn't show though the grille grid...
You could also paint it if want also..Some people paint the outer edge of the grille the same as the color of
the car.. I just left mine all black and save the money of getting it painted.. It works for me.. Do what you like best.
Then the grille has 3M 2 sided tape.. I just pell back about 2 inches of the ends and folded them over the grille front so you can pull them off when you get the grille positioned where you want it...
Good Luck ..
Old 07-28-2005 | 01:10 AM
04MonteLS's Avatar
that grill looks cool and all, but damn, $100??!!
Not that cool
Old 07-28-2005 | 01:36 PM
Ca$$e's Avatar
Thanks RifrechSS
Old 07-29-2005 | 08:29 PM
Ca$$e's Avatar
You wouldnt happen to know anything about the lower grill insert would ya?
Old 07-29-2005 | 08:53 PM
04MonteLS's Avatar
I know something about it.........it's overpriced
