RE: wax/swirls
I did this on my old car. Black Vdub Golf:
1. Washed the car twice. 2. Mothers clay bar 3. Sprayed car down again and let it dry 4. Mothers Cleaner wax(3 light coats) 5. Mothers sealer compond (3 light coats) 6. Mothers Wax (3 light coats) 7. Then I used Nu Finish Polish 2 light coats Then car was blacker then black after I was done. It was all done by hand and was pretty tired that night. |
RE: wax/swirls
After cleaning off all the old wax, I'm now using Liquid Glass on my black SS. As someone mentioned, the instructions specifically state to make the application in back-and-forth movements - not circles. Also, they say that if streaking occurs on dark colors, rebuff the area with a damp cloth. This has worked well for me, and might work with the wax you're using as well.
RE: wax/swirls
ORIGINAL: bonang Then car was blacker then black after I was done. It was all done by hand and was pretty tired that night. |
RE: wax/swirls
I followed Propitious and Space's advice and i went out and found the Meguiar Clay Bar and worked my car over I also got the Scrath remover compound and the Wax. And WOW! My Swirls were GONE!
http://i229.photobucket.com/albums/e...r/DSC02368.jpg |
RE: wax/swirls
Buffing is the way to go. Stop-off at a Body Shop and have someone there tell you about Buffing-out paint. You need: The Right Buffing Compound The Right speed Buffer. The Right kind of Buffing Pad. When you have all your ducks in a row ... you put the Compound on the car ... fire-up the Buffer and restore the finish to like new! But you need the right ingredients ... close don't get it. |
RE: wax/swirls
I have read that the Porter Cable 7424 is what we should use. Is it worth buyingor should I save my moola?
RE: wax/swirls
Here is the link for it. Cheapest I could find. http://www.tools-plus.com/porter-cab...m_term=P-C7424
