Towel Care
Old Apr 29, 2010 | 12:55 PM
gothkid's Avatar
Default Towel Care
I have seen alot of talk about microfiber towels, and when web surfin i came accross some things to no.
Caring For Microfiber . . .
Microfiber towels can be very expensive and are a very important detailing accessory. Proper microfiber care can extend the life of your towels and keep them soft and absorbent. Here are a few rules to caring for your microfiber towels:
1. Avoid dropping your microfiber on the ground. Microfiber is very “grabby” and whatever dirt it picks up is often difficult to remove from its knap even after washing.
2. Wash your microfiber after each use.
3. Always wash your microfiber separately from any other type of fabric to avoid picking up lint from the other fabrics.
4. Never use bleach as it will eventually stiffen the towel’s fibers.
5. Never use fabric softener as it will clog up the knap of the towel making it less absorbent.
6. Use a detergent with that does not contain perfumes, bleach, fabric softener, or a wrinkle releaser. You can also use a dedicated microfiber detergent like Micro-Restore, Pinnacle Micro Rejuvenator, or Sons Der Wunder Wasche.
7. Always wash your towels in warm or hot water as this will help to remove polish & wax residue from the towel.
8. Adding vinegar to the rinse cycle can help to release any remaining residues on the towel.
9. Store your microfiber in an enclosed container where it will not accumulate dust or get dirty.
I wanted to add this for all Car Bra owners
Using a Car Bra . . .
It is not advised that you use a vinyl bra on the front of your car. Dirt often gets trapped under a car bra and can rub against the paint resulting in scratches. Also, vinyl car bras are not made of a breathable material. This traps moisture in between the car bra and the paint. Eventually, the moisture will migrate into the paint resulting in the paint looking foggy. If you do insist on using a vinyl bra on your car, remove it often and clean away any dirt trapped behind it. Also, remove it whenever you wash the car or whenever the car becomes wet. Alternatively, a clear bra which is adhered to the paint has none of these negative aspects.
Old Apr 29, 2010 | 10:03 PM
captaindamnit's Avatar
thanks! I was looking to get a bra for my car this winter. I'm guessing clear is the way to go then!
Old Apr 29, 2010 | 11:23 PM
Enzo354's Avatar
STILL SLOW
I ALWAYS drop it in the dirt somehow. Sigh, or leaves get in it when Im waxing.
Old Apr 30, 2010 | 01:39 AM
gothkid's Avatar
It happends but to be sure look over the towl and shake it out, or grab a new one just to be safe.
Old Apr 30, 2010 | 04:44 PM
Oh yea, I always shake the **** out of my microfibers. lol
Old May 1, 2010 | 08:18 PM
Jomao_o's Avatar
lol, i buy packs from autozone.
They're inexpensive IMO.
and yeah, they tend to find their way to the ground lol
Old May 2, 2010 | 12:16 AM
gothkid's Avatar
Over a month that can add up tho where a wash and dry might have saved you money
Old May 2, 2010 | 01:01 AM
Budsjlm's Avatar
i have more microfibers than i truely need i have droped afew and gotten a good amoumt of crap in them, that when they get demoted go oil rags
Old May 2, 2010 | 01:13 PM
iMSeRiOuS's Avatar
I'm not caring for my towels very well at all.... I just put them in with the other towels... I use softener and I break just about every other rule LOL
Old May 2, 2010 | 09:51 PM
gothkid's Avatar
Might wanna get some new ones and use those as interior rags
