touch up paint. where to get spray can?
Old Aug 9, 2011 | 11:34 PM
blackbeauty89's Avatar
Default touch up paint. where to get spray can?
anybody know where to get a spray can of touch up paint? i have this little pen/brush i bought from autozone, but i have quite a bit to touch up and i don't want to use a tiny paint brush.
Old Aug 9, 2011 | 11:35 PM
xxtheshockerxx's Avatar
RED DEVIL
just buy a bigger brush
Old Aug 9, 2011 | 11:55 PM
i'd prefer spray, but if i can't then i guess i'll have to. the area is my wheel well and it's been missing paint for awhile and starting to rust. plus using a brush isn't quite as smooth looking as spray, but if i have to then i will.. just wondering if anyone knows
Old Aug 10, 2011 | 06:50 AM
03SSLE's Avatar
I've used Duplicolor Perfect Match spray paint followed by a coat of their clear coat with excellent results in the past. If it's not on the shelf of a local auto parts store they can probably order it for you. Just take your time and don't get in a hurry. A meticulous prep job followed by several thin coats (wet sanded between coats) worked well for me. I used 2000 grit paper for the final wet sand and the finish came out very smooth and glossy.
Old Aug 10, 2011 | 09:35 AM
Budsjlm's Avatar
i do belive you can get spray cans from car quest, you will need your paint code
Old Aug 10, 2011 | 09:48 AM
zzapultimate's Avatar
I'm looking for some spray touch up paint too. Are there any places online anyone reccomends? Such as I tell them I have a paint code of "11U" and they'll send me a can of matching paint?
03SS- Is the duplicor stuff available online? I know I can get the clear around here abundantly.
Old Aug 10, 2011 | 11:01 AM
03SSLE's Avatar
Some places won't ship paint, so you'll have to check the individual policies on their web site to see if they will or not. IIRC I think Summit ships paint. If the stores like Autozone, O'Reillys, etc won't ship to your home you might be able to order it from a local store and have them ship it there.
Here's the application guide for the Perfect Match:
http://duplicolor.com/appGuide/applicationGuide.pdf
Old Aug 11, 2011 | 05:06 PM
my00monte's Avatar
I used the Duplicolor Perfect Match paint. It matches PERFECTLY! All you need to know is your paint code and then match it to the spray paint. This stuff is great.
Old Aug 11, 2011 | 09:38 PM
Where did you get your Paint 00Monte?
Old Aug 11, 2011 | 10:53 PM
my00monte's Avatar
I got mine from Advance Auto Parts, but I saw it at Autozone, and O'Reilly's Auto Parts too. It's pretty cheap for what it is.. only $7. I'll stand by it 100% as long as you get the right paint code.
