Tire dressing...what do you use?
Old Aug 20, 2005 | 03:21 AM
04MonteLS's Avatar
Default Tire dressing...what do you use?
Is this the stuff you were telling me about Mickey?
I can get it the same place I got the heavy and medium cut leveler! $9.95 for a 32oz bottle...that's alot of tire dressing!! Most dressings cost what, $5-$6 and you only get like 16-20oz.
Or is it this stuff?
This stuff is a little more expensive, but still a better deal than what you can get locally. It's $12 for 32oz bottle, or you can get two of em for $22
or you can get this whole kit for $25
Old Aug 20, 2005 | 12:16 PM
Ca$$e's Avatar
Default RE: Tire dressing...what do you use?
Hmmm that whole kit seems like a good buy..
Old Aug 20, 2005 | 01:49 PM
04MonteLS's Avatar
ORIGINAL: Ca$$e
Agreed.
Now that I've found a Hi-Temp vendor, my shed is gonna turn into a Hi-Temp showroom
Old Aug 21, 2005 | 07:48 AM
mickey's Avatar
yep that is the right stuff
i have never used the wheel cleaner that is a new one since i have used thier stuff we didnt use the tire cleaner ethier we just used dawn dish soap and a scrubber to get crap off them.
but that stuff works well. and if you look around they should have somthign for your dash also.
but we used to cut the tire dresser down some with somthign (not sure what he used never mixed it) for the dash
Check around thier site you might find it to and it was great stuff also.
did you get the stuff in yet? and get a chance to use it?
Old Aug 21, 2005 | 08:21 AM
04MonteLS's Avatar
ORIGINAL: mickey
which one though, the grape stuff or the premium stuff?
I have a feeling I'll be getting alot of Hi-Temp stuff now, I am very pleased with thier product.
Old Aug 21, 2005 | 12:16 PM
montejass's Avatar
I've been using Meguiars Hot Shine High Gloss Tire Spray and I've been pretty happy with it so far.
Old Aug 21, 2005 | 02:18 PM
03SSdriver's Avatar
JMO....
The best stuff i have ever used is Goodyear tire care.
Very low gloss. ( i don't like shiny tires-not natural looking)
It makes the tires look like they just might be new.[8D]
Problem is, i can't find it anymore.[:@]
I have went through the Goodyear site... no luck.
A freind gave me this stuff called armor-ex.. dosn't work too bad.
Tj
Old Aug 21, 2005 | 04:05 PM
04MonteLS's Avatar
ORIGINAL: montejass
I used that stuff back when it first came out, it doesn't do a bad job at all. However, cost in an issue and it's petroleum based, which is also an issue. You pay prolly $5-$7 for a 15oz. can, for only $9.95 you can get a 32oz. bottle of Grape tire dressing, which is water based. What's the difference between oil and water based tire products?
Oil-based silicone dressings are non-penetrating coatings that seal rubber and vinyl. They are very good at providing a protective surface barrier. Oil-based silicone dressings create a glossy film that never really dries. I'm not a fan of these products, as most contain petroleum distillates as a cleaning agent. Petroleum distillates are harmful to rubber and vinyl, and will cause cracking.
Water-based dressings do not contain oils or petroleum distillates that can harm and dull the surface of rubber and vinyl over time. Water based dressings actually penetrate the tire to provide deeper protection, but it's this penetration that is the main reson these dressings don't provide the shine of their oil based competitors. Most water-based dressings offer a non-greasy, more natural looking satin finish; however, they are not as durable as the oil-based products.
Old Aug 21, 2005 | 04:08 PM
04MonteLS's Avatar
ORIGINAL: 03SSdriver
JMO....
Tj
I would suggest you get away from oil based products and move over to the water based side, the look is exactly what you're looking for. And if you order the Hi Temp Grape tire dressing, you can get a 32oz bottle for $9.95!!!!
Old Aug 21, 2005 | 06:05 PM
montejass's Avatar
I like a high gloss shine on my tires. How long does Hi Temp Grape tire dressing last?
