Shine for Ride
Old Sep 4, 2007 | 02:29 PM
GrandPaDave's Avatar
Default RE: Shine for Ride
NanoWax® Spray
Easy, no-haze carnauba spray wax for a high-gloss shine and protection
Because time spent waxing, is time spent not doing something else! Eagle One has developed a spray wax that is truly easier to use without compromising the results. Provides long-lasting protection and a great shine.
NanoWax spray is a no-haze spray wax that utilizes tiny nano-sized carnauba wax particles to penetrate deeper into the paint surface, providing better protection, a deep, glossy shine that rejuvenates the look of your paint and lasts longer than conventional spray waxes.
[ul][*]Quick and easy to use. Just spray and wipe to a radiant shine, no buffing necessary[*]Spray bottle provides control and ease-of-use[*]Conceals minor scratches and swirl marks[*]Nano-sized carnauba wax particles eliminate smearing and streaking[*]No white residue left behind[*]Protects from harmful UV rays [/ul]
[ol][*]Wash car with Eagle One car wash or Bucket-Free car wash and dry well with a clean chamois or towel.[*]Spray a small amount (2 or 3 sprays) of wax directly on to the surface of the car.[*]Wipe clean with a microfiber towel, and continue to spray and wipe as needed.[*]No need to wait for the wax to haze and no buffing needed.[*]Can be used in the sun or shade.[*]Using a microfiber towel wipe to a brilliant shine. [/ol]Q. Is it safe to use NanoWax Spray on my windows, trim and wheels?
A. Yes, NanoWax Spray can be used on all exterior surfaces with no adverse effects and will also provide additional repellency benefits against water and dust.
Q. Will NanoWax Spray leave a white residue on my moldings and in the seams of my car?
A. No. Unlike conventional waxes or polishes, NanoWax Spray does not leave behind any powder residue due to the nano-sized wax particles in the formula. This provides an easier and faster way to wax your vehicle.
Q. Will NanoWax Spray streak with overuse?
A. NanoWax Spray will not streak with overuse. If you experience streaking it could be due to a dirty or wet towel or dirt left on the surface of your car. Before applying wax, make sure that you start with a clean, dry surface and cloth.
Q. How long does NanoWax Spray Last?
A. NanoWax Spray is more durable than most other spray waxes currently available. Frequent use will extend the duration of protection. A good rule of thumb is to reapply product when you don’t see water beading on the surface of your car.
Q. How much will I need to use to achieve the best results?
A. NanoWax Spray should be sprayed evenly on the surface of your car. About 2-3 sprays per panel should be sufficient.
Q. What type of applicator should I use to apply? What should I use to wipe it down?
A. NanoWax Spray does not require an applicator as it should be sprayed directly on to the surface of your car. We recommend that you use a clean microfiber towel to remove for best results. A dirty towel will cause streaking.
Q. Is this product safe for all paint finishes?
A. Yes. NanoWax Spray was developed to provide protection and a deep gloss shine for all painted surfaces, including boats, motorcycles and trucks. [/align]
THE FOLLOWING COMMENTS WERE TAKEN FROM ACTUAL PRODUCT TRIALS OF AN EAGLE ONE NANOWAX SPRAY CONSUMER TEST
Submit a Testimonial
It is so easy to apply and wipe off. Also, before I used the product I wiped my hand across the vehicle and it didn't want to slide across the vehicle very well; after using the product my hand just glided across the vehicle. Very impressive.
[hr]
I felt that this product produced a better shine than other products that I have used. I also noticed that after it rained I had very good beading of water on my car.
[hr]
It gives an exc
Old Sep 4, 2007 | 05:05 PM
scc24540's Avatar
good lord space jr LOL so thats what nanowax is hmm
Old Sep 4, 2007 | 05:33 PM
ORIGINAL: scc24540
Why, I resemble that remark![sm=alien.gif][sm=alien.gif][sm=alien.gif][sm=alien.gif]
Old Sep 4, 2007 | 06:06 PM
scc24540's Avatar
oh lawd i might get abducted now
Old Sep 4, 2007 | 08:25 PM
TheFullMonte's Avatar
LOL!!! you guys are crazy! lol... Nanowax huh? Nano-Nano Wax?...uhh... Mork form Ork...uhh Space...abducted??? ......this is too much...LOL!!!
Old Sep 5, 2007 | 12:22 PM
ORIGINAL: TheFullMonte
I use it once every 2 months on my car. People think I just drove it out of the showroom.
The car has never been garaged either and that says alot seeing how the car came from the hot Arizona sun to the hot California sun.
Old Sep 5, 2007 | 01:05 PM
ORIGINAL: scc24540
`Chris ? Are you pick'in on my
`Net MCFGrandfather ?
We will have to pick you up for
re-programing @ our Nano Center
Fire upon command GP `Dave : )
Old Sep 5, 2007 | 01:15 PM
LOL! All done Uncle Space!!
[sm=shootshoot.gif]
Old Sep 5, 2007 | 04:10 PM
04 Intimidator's Avatar
ORIGINAL: scc24540
That is the best roast I've seen here for a long time!!!
Old Sep 5, 2007 | 04:19 PM
This may be a good product, but I'm calling BS on the results/marketing hype. A nano is 1 billionth of an inchso they are using a technology only the superpower governments have access to for the sole purpose of cutting wax down this small to drop into a cheap container and sell for 5 bucks
or
they are melting a 1 inch cube of wax and mixing it into 4.3 million gallons of solution and still selling it for 5 bucks. ( http://www.metric-conversions.org/vo...id-gallons.htm)
I would go with the last and say your are better off purchasing any other wax brand on the market just on principle.
