Razzi Ground Effects
Does anyone know if Razzi Ground Effects are difficult to install? Or would it be encouraged to take my Monte Carlo to a local dealership/mechanic? Also, are dual exhausts required for the rear air dam? Thanks.
Here is a link for reference:
http://www.razzi.com/vehicles/chevro...2dr_1164.shtml
From what I have heard they are very labor intensive. Are you fair in your machanical abilities?
The package will have to be painted, I would let your body shop do it for one reason and one reason only in my book... You screw it up you get to buy a new part, they screw it up they get to.
BTW, the kit comes with templates for you to follow and requires holes to be drilled in your existing panels. The hole will be there regardless for the dual exhausts. It would look a little out of place without something poking out of both sides IMO...
When are you getting yours done??
Well, first allow me to introduce myself. I'm only 16 and I (luckily) have a used silver 2004 Monte Carlo LS (currently 23,000 miles and runs very well). I also have a rear-end spoiler (pace-car). I have the ugly ordinary one-exhaust system. I would like to get this Razzi Ground Effect procedure done sometime next year, but it will probably be done until I'm 18.
ORIGINAL: Scooze
No, duals are not "required", but it sure would look better with two than with one.
they are not to hard to do. but also look on the link you supplied and look farther down the page you will see a kit that has a dual option for a dummy pipe on it also. So you can have the look of duals but not actually have them .
ORIGINAL: Scooze
I could just order all the equipment (exhaust system + Razzi Ground Effects kit = around $1,500) online and take it all to a body shop and have them do it, couldn't I?
So my Monte Carlo should eventually look something very similar to the ones here:
http://betterrides.com/pro493821.html
http://betterrides.com/pro493823.html
Does anyone know if the Razzi Catback Exhaust system is good or are there better ones? I'm not looking for something too loud, but something decent that also increases horsepower.
if i was doing it i would take it to the bdy shop for the kit then to the mffler shop so they can hang it right and make it look right Also.
not to mention the body shop could probbly do it but would you rather have a dentis do your surgury?
ORIGINAL: mickey
