polishing up that ole stainless exhaust system
Old Mar 11, 2013 | 06:40 PM
Default polishing up that ole stainless exhaust system
I plan on polishing up my magnaflows for the Monte Show Car nationals this year as they will roll a mirror under the car.
I was concerned because although my mufflers are shiney my pipes got blue and nasty from the heat. I found this link on fixing the problem with little money and lots of elbow grease. I hope it helps you. You all know how picky I am with the Deuce.
Cleaning/Polishing Stainless Steel - Auto Geek Online Auto Detailing Forum
Old Mar 11, 2013 | 07:25 PM
That's a nice tip I never thought of doing it that way..I'll have to try it..I used sandpaper with water...
Then grab your 1000 grit sandpaper and again rip the sandpaper into four equal pieces. Then use the sandpaper together with the metal polish to get your desired results quicker. This way is faster than just using sandpaper alone;
Old Mar 11, 2013 | 08:24 PM
Wow that really looks great. I think you will be happy with the results. Are you gonna take it off to do it or crawl around underneath it?
Old Mar 28, 2013 | 01:01 PM
Mels SS's Avatar
To much work just get it Ceramic coated
Jet-Hot Ceramic Coatings
Old Mar 28, 2013 | 01:05 PM
SSilver's Avatar
I was looking at my Magnaflow exhaust today and it looks like crap. I thought Stainless Steel was supposed to be, I dunno, Stainless??
I guess I'll have to spend a day getting it to look like it should...
Old Mar 28, 2013 | 02:46 PM
TheMonteMan's Avatar
agreed mine looks bad too. the mufflers and resonators are the only things that came polished. at least my muffs look ok since theyve been in the basement for 4yrs.
Old Mar 29, 2013 | 09:30 AM
As soon as I saw this thread on the main page I knew it was you Tadd. Look forward to seeing the results.
Old Mar 29, 2013 | 11:27 AM
My exhaust is painted with high heat exhaust paint - it's silver - don't have to polish anything.
Old Mar 29, 2013 | 11:44 AM
Ya going to crawl under the Deuce. I had thought briefly about painting the pipes.... but decided stainless is awesome if is shined up right.
Yes it is a LOT of work but I don't mind
Old Mar 29, 2013 | 05:32 PM
xxtheshockerxx's Avatar
RED DEVIL
good luck Tadd. Seems like alot of work but will be well worth it in the end. mine looks like crap too but i would have to be really ambitious to polish mine out
