Plastic Panel on Truck Lid of the '98
Old Aug 6, 2009 | 04:41 PM
MarkIV396's Avatar
Default Plastic Panel on Truck Lid of the '98
My '98 Monte is all black. The Trunk lid has a "Plastic panel" above the
fluted Back-up light panel that is looking really dull. I've toyed with idea
of getting it repaced with a new one -- or using a "plastic polish" on it
to see it will get rid of the "haze"...
Any Ideas or experience on this??
Thanks!
Old Aug 6, 2009 | 05:09 PM
skylark65's Avatar
the black panel? i just got a can of flat black " trim " paint, duplicolor i think, that i was gonna use to freshin up spots like that, my windsheild wiper arms, and maby do some decals... i have not gotten to use it yet, but i will let you know how it turns out.
Old Aug 6, 2009 | 05:30 PM
mrl390's Avatar
The flat black paint will look just as bad or worse than the dull trunk panel. If your panel is in good shape without cracks or deep scratches then you could just polish it with a buffer/polisher. I would treat it like you would if you buffed a headlight. You may even be able to get away with just buffing and no wetsanding. I polished mine by hand with some 3M machine polish and it looked good for a week or so. It should last longer if you machine buffed/polished it.
Old Aug 6, 2009 | 09:34 PM
The Popcorn King's Avatar
I painted mine white ( body color ), but its the same if you wanted to paint it black.
First clean it real good with Dawn dish soap. Let air dry and use an adhesion promoter. My preference is BullDog. Then you can spray on some balck single stage paint. Why single stage? You dont have all the steps of Base coat/ Clear coat. I haven't had a single problem with mine and its been almost 6 months since i painted it.
Old Aug 7, 2009 | 08:21 AM
http://mymonte.com/discussion/index.php?showtopic=27502
Read that. Good way to do it for like $7
Old Aug 7, 2009 | 12:14 PM
MarkIV396's Avatar
Default Trunk Lid Plastic...
That looks pretty good! Hate spend $$$ for new one! I'm
not real good with spray paint. I would never make it in
a Gang!
Thanks!
Old Aug 7, 2009 | 12:26 PM
Also good to use on your headlights
sunniss
Aug 3, 2011 02:17 PM
BeachBumMike
Mar 27, 2007 02:25 AM
fastback4
Dec 24, 2006 01:46 AM
Scooze
Sep 19, 2005 02:23 AM
