Pinstriping question?
Old Feb 28, 2010 | 10:52 AM
pizzarrhea's Avatar
Default Pinstriping question?
I've seen posts on people saying they pinstriped their Montes but I wanna know where I can buy pinstriping?
Old Feb 28, 2010 | 11:50 AM
irulesoha's Avatar
Any auto supply store should have them. Try wallmart and target too. They might.
Itll be about $15 for 10x more than what you actually need.
And on pinstriping, thinner the better.
Old Feb 28, 2010 | 12:00 PM
Enzo354's Avatar
STILL SLOW
Yea get the stick on stuff and drive it around, see if you like it or not. If you do, get it done in paint by a professional. If you don't like it, go to a car wash, get it all soaked and peel it off haha.
Old Mar 1, 2010 | 10:33 AM
nascar43's Avatar
Default pinstriping
You can get pinstriping from most Auto Body / Paint supply stores. You may try
keying in 3M stripe colors on the web and there is a site that I found not too long
ago. The colors are for for 07 but they should still work. I got a roll of Silver
metallic with another name attached to it for around $16.00. Yeah, not cheap
but it will last a long time. Do you know anyone who works in a body shop ?
Usually there is plenty of excess pinstriping tape in stock. You might be able
to get it free or pay a couple of $$ ?
EDIT : Here is the link for the color chart. http://www1.futureelectronics.com/do...UTIONS/740.pdf
Old Mar 1, 2010 | 12:35 PM
pizzarrhea's Avatar
What measurement would I need for the side lines on the body? Is it easy to apply
Old Mar 1, 2010 | 04:05 PM
nascar43's Avatar
Default pinstriping
.....There is No Real Set Measurement that I know of.
I used a blue masking tape ( 3/4") and tore off 4 - 5 small strips
and placed them side by side lllll with various lengths.
Use starting points such as the end of Qtr panel, Door Edge , Door handle
edge to place your masking tape markers. ALWAYS cut enough pinstripe to
allow for stretching and trimming off. 8 - 12" is always good. It's a little tricky
to apply but it's not hard. Pick your starting point ...... stick.....and walk to your
end point.......kneel down and lay it down gently.......if you like it......use a rag and
press it down......then pull clear off.......taper the top stripe over the bottom....
and trim off with exacto blade......
Hope this helps ?
Old Mar 1, 2010 | 06:11 PM
Enzo354's Avatar
STILL SLOW
Trim with scissors. You'll end up running through the tape and going into your paint by accident.
Old Mar 1, 2010 | 10:33 PM
Montgomery Carlo's's Avatar
Does any one have any pics of a white monte with pinstripes? itd be nice to get an idea before i go out and buy it plus i dont really want to stand out in the cold and do it in the winter
Old Mar 1, 2010 | 10:44 PM
Enzo354's Avatar
STILL SLOW
I saw one for sale in norfolk hold please haha
I prefer the stripes at the bottom of the indent myself.
Old Mar 1, 2010 | 11:11 PM
Hey, thanks alot. im likeing the look of that! looks like im gonna have to go to the store and pick some of that tape stuff up and seee how she looks on mine
