I'm Bugged
I would like some opinions and suggestions for the best cleaner to
remove bugs from my front bumper cover ?
I have used Turtle Wax Bug cleaner and they are still in there. I'm concerned that the bugs are imbedded in the paint to much.
Thanks.
Richard.
Thanks.
Richard.
I soak the area first, spray some simple green, let it soak for a little bit and wipe em off. I do that for the ones that seem embedded in the paint, lol, but usually the mostly come off after they are spray with water and left soaking a bit.
Detailing secret for getting bugs off. Use engine degresser on the bug infested area.
NOTE make sure its a non acid, let is sit for like 5 seconds and then use a power washer and spray it off.
You may need to wax/polish afterwards
If you get some hydrogen peroxide, the stuff in the brown bottle, and dilute it a little with water, it makes an excellent bug remover. Put it in a spray bottle and spray it on, let it sit a few seconds then wipe the bugs off. Some people even say a wet dryer sheet will take bugs off, but Ive never tried it.
Dryer sheets do work. I used some used Bounce sheets because I heard the same thing and was surprised. They work as good if not better then the bug sponge that I used to have. Just dunk the sheets in the bucket after washing the car and go at the bugs.
......Well then, I guess I will try the laundry sheets and see what happens. If that doesn't work...I'll call Orkin.... LOL !
I hope to have NEW photos by this coming week. I have applied
a pinstripe to the car since my last photos.
