it has started! Painting my engine cover!! (AGAIN) buahaha
well option 2 it will be peoples
cleaned it up and sprayed the black center, tomorrow the masking will be done and i'll be laying down the white, im using high heat engine paint for the black and white, then i will use duplicolors scratch fix pen/brush on the lettering.. TORCH RED... ohhhh yeaaa
then finishing everything up with heat heat CLEAR
CLEANED UP
BLACK CENTER, in flat black but will shine up when the clear is on
CLEANED UP
Why not? I'm about to start the same project, using touch-up red on the letters and finishing with clear coat. Is that not a good idea? This is my first try at engine bay detailing and I'd appreciate any advice. Thanks!
:p
