Detailing later today
Hi `Jonny,
Super Detail as always...Thanks for posting your b-4 & after pictures...That's a LARGE Expensive SUV 4-Sure...
I hope the owner gave you a BIG TIP for your talents & hard work...$$$$...What's next ?
How's your Monte ? Is it detailed ?
`Jonny, Good Luck on getting your Monte back 2gether.
Sometimes it takes time to get important things done + $'s really helps a lot....Wish you the best on getting your Monte back on the Road... + more high paying customer's in your business.
Thanks 4 the update.
Wish I could do all that in 6 hours. haha. I spent 15 hours on a black Hummer H2 that got my level 3 detail and just a light interior cleaning. But I had to spend some time on it though as the paint was so very soft unlike normal GM paint thats rock hard like my monte. I could barley touch it with my new Flex PE14 Rotary buffer, I had to do it all with the DA Polisher
Have you ever tried the Meguairs Soft Buff 2.0 Pads. I use the 7" ones on my Rotary they work nice(also I use the 4" ones). They have the Maroon ones that are for extreme cutting. There Yellow ones that are for all around they work fantastic and Black ones that are a no cut pad thats great for fine polishing. I Think there the best pads I have used they are currently replacing all my Lake Country CCS pads except the red ones that I use for machine waxing.
With the Meguiars Yellow Pads I can compound(usually M105) to remove swirls and then pick up a new Yellow pad and polish out to a high gloss(usually M205), Depending on the car though I need to polish with a DA do finnish out the car absolutely swirl free. Usually for the DA I use the Meguiars Black pad with Wolfgang Finishing Glaze 3.0(it often makes the paint look even more wet too)
Sorry if I made this a bit long but I just wanted to say what I normally do and I highly recommend trying out those pads, I can post a link to them if you would like to check em out.
