Cleaning Glass
Old Jan 21, 2011 | 08:53 AM
Cowboy6622's Avatar
Default Cleaning Glass
How do you guys do this? I usually use the Windex Auto stuff and some microfiber rags and a towel. However, my windshield, despite these efforts and like 30 minutes trying to clean them, has slight little water spots to it. They show up a lot at night. What do you guys use and how do you go about cleaning the windows, inside and out? I thought about that Invisiglass in the aerosal cans. What works for you guys?
Old Jan 21, 2011 | 09:31 AM
..Hi `Duane, Cleaning auto windows is that one job that I do not like to do, but I've found Stoner's & Invisible Glass cleaner works great using a micro filter & also coffee filter's...
Also for spots, mineral build `up I use distilled white vinegar..
Check the below links for additional infor...Good Luck & I hope the below helps you and member's....
Related Ads
Articles & Videos
More
Old Jan 21, 2011 | 11:16 AM
jaws2008's Avatar
GOT SPL
I use This (http://www.autogeek.net/mg12001.html) Glass Cleaner, Its a powerful cleaner and never leaves streak, I use Microfiber towels.
I would try and ClayBar the windows first and see if that helps, some of the water spots
Old Jan 21, 2011 | 01:14 PM
Stoner's should be my brand. But I use some 3M stuff. ACDelco part #992727 is also very good.
Water spots on the outside seem easier to eliminate then inside streaks IMO
Old Jan 21, 2011 | 01:23 PM
Blazed SS's Avatar
IT HERTZ
this is what I used last summer and was the only stuff I found to get the hard water spots of my car windows I did use about 1 bottle but they are all gone even off the sunroof
http://www.napaonline.com/Search/Det...812_0006405902
and after getting all the spots of I was able to rain-x the windows and they never came back
Old Jan 21, 2011 | 01:44 PM
Windex and a 0000 (or 000) scour pad
Old Jan 21, 2011 | 06:56 PM
Stoner's Invisible glass - I kinda like the aerosol can the best.
Old Jan 21, 2011 | 07:15 PM
Mels SS's Avatar
Use this to polish!! It will take off all the water spots than clean with widex
http://www.zainostore.com/Merchant2/...oduct_Count=16
Old Jan 21, 2011 | 07:24 PM
mrl390's Avatar
A super fine steel wool like 0000 will take off any water spots and grime without hurting your glass. I use Sprayaway glass cleaner. It comes in a white and blue aerosol can with a maid on the front. The stuff works awesome. The trick is to use one towel to do the cleaning and another dry one to wipe off the excess moisture so it doesnt streak. I usually go over the windshield two times and the side windows just once. For some reason the windshield gets really greasy and streaks if you just clean it once.
Old Jan 21, 2011 | 09:16 PM
I use Stoner's Invisible Glass. Works great for me. And I found a six pack of the cans at Costco.
