Clay Bar?
Old May 10, 2011 | 06:43 AM
Default Clay Bar?
I hear so much talk about this and have no idea what it is. Please enlighten me. Thanks
Jerry
Old May 10, 2011 | 07:12 AM
Hi `Jerry,
We can't learn `if we don't ask 4-Sure...
Below are the links I had in my files on this subject.
Contains some great infor & I hope it helps you 4-Sure : )
How to Clay Bar
5 min - May 14, 2007 - Uploaded by MaximusZTS
How to clay bar a vehicle. Hosted by Mike Phillips of Meguiar's.
www.youtube.com/watch?v=yfEfLGL59GI
More videos for what is a clay bar used for »
Detailing Car Clay Bar - Auto Clay Bar for Car Paint Contamination
Yet used properly, detailing clay is not abrasive to your car's paint; it is abrasive to paint contamination. CAR CLAY BAR FORMULATIONS Detailing clay ...
www.autopia-carcare.com/inf-clay.html - Cached - Similar
How to use a clay bar on your Car
Step by step information on how to use a clay bar on your car, including pictorials & videos on how to detail your car. Do It Youself auto detailing.
paintcarendetailing.com/clay.html - Cached - Similar
Old May 10, 2011 | 08:29 AM
saigashooter's Avatar
The clay bar is a lubricant and a soft clay used to remove deposits from your paint.
the lubricant is sprayed on, and allows the clay to glide across the paint. As it does, it hits small and large particulate and captures it int he clay. this makes the paint smoother, and prepares it for polishing and waxing.
Old May 10, 2011 | 08:58 AM
03SSLE's Avatar
If your paint hasn't been cleaned in quite a while using a clay bar will bring it back to life. The paint on my Monte wasn't too bad, so as an alternative I used the Meguiars Ultimate Compound instead and achieved the same results. I topped it off with a coat of their NXT Wax and the results are amazing.
Old May 10, 2011 | 09:50 AM
gothkid's Avatar
Now how do you no when you need to use a clay bar?
There is no definitive schedule that can be applied to all cars. Many factors play into how often claying is recommended for your vehicle (where your car is stored, how often you wash it, what environmental elements are in your area, etc). However, you can easily determine for yourself how often to clay by performing a simple test. Every time you wash, your vehicle, run the palm and fingertips of your clean hand across the top surfaces. If you feel a rough, bumpy surface, it is time for you to clay. Depending on the mix of factors that affect your vehicle, you could benefit from claying as often as weekly to as rarely as once a year.
to learn all about clay bar go here
meguiars.com: FAQ - Detailing Clay&faqQuestionID=66&section=_66#_66
Old May 10, 2011 | 10:23 AM
MarkIV396's Avatar
Default Clay Bar...
Originally Posted by KidSpace
Hi `Jerry,
How to Clay Bar
I did this to my Black '98 MC LS & couldn't believe the difference it made. Like I have a new paint job. Now I need to go to paintless dent removal to get a few dings off the doors!
Old May 10, 2011 | 11:09 AM
Take the plunge, by the clay bar kit (plus an extra spray detailer + more wax) JUST IN CASE, and take a nice long beautiful cloudy cool day and just spend all day outside having fun. You WILL be astonished at how smooth the paint feels and how much nicer the car will look afterwards.
Old May 10, 2011 | 11:29 AM
jaws2008's Avatar
GOT SPL
Maybe ill post a how to vid in the "Detailing Vids" thread since this is often a FAQ.
Old May 10, 2011 | 11:34 AM
RickAKATed10's Avatar
Photobucket
Stop asking questions and do it! lol
Old May 24, 2011 | 11:42 AM
05JLMonte's Avatar
i used the mothers kit, it took small oxidation rust spots off my white 05 monte.
