1st mcf member to receive jarheadbobandmax trunk mat
Old Sep 9, 2009 | 07:17 AM
jarheadbobandmax's Avatar
Photobucket
Chris a you bidding for a sale position? Thanks everyone for the feedback. And I,m working on the #3 tribute.
Old Sep 9, 2009 | 07:49 AM
Photobucket
Cully if you look at the panel you will see four round tabs which are nylon christmas tree fasteners similar to interior tabs. Four 1/4 holes drilled into the lid bracing useing the panel itself as the guide and it simply pushes right into place. useing the push tabs allows for a tight snug fit with no movement that may cause rattle or noise in the trunk, also the panels will not fall from place as they may with the use of velcro or two sided tape which may lose thier adhiesion in damp weather or thru time in addition to leaving glue residue should you remove the mat. The drilling is safe and simple when the right tools and attention is used. A center punch to mark the holes. a small flat tipped bit to run the pilot hole and a 1/4" flat tip bit to set the final holes, Use drill bit stop collars to limit the depth and with the use of the flat tip bits the cut will not want to pull the drill bit along giving you complete control of travel. My mats are pre-drilled to mate up with the lid braces for the 2000 -07 lids and once I get the templates made I hope to be able to make them for every generation Monte's
Old Sep 9, 2009 | 08:50 AM
1FastMonteCarloLT's Avatar
I still want to see one with a white bowtie! If it looks good then I'll get one too
Old Sep 9, 2009 | 08:52 AM
They are just simply fantastic, and I thank you from the bottom of my heart for giving our member's such a unique and high quality item that simply can't be purchased anywhere else
Old Sep 9, 2009 | 09:25 AM
Jimbo's Avatar
me too there needs to be more accesories for the 4th gen not enough...that mat would look so sick in my trunk at lead east next year
Originally Posted by Budsjlm
looks awsome... wish someone would make somthing like that for a 4th gen
Old Sep 9, 2009 | 11:24 AM
RickAKATed10's Avatar
Photobucket
Looks nice. It's on the wish list.
Old Sep 9, 2009 | 12:11 PM
drewskie043's Avatar
i'll second that statment! except i would want mine all black, bowtie and all.
...or i would be very interested if i could get one with the "RS" to match my badging. basically the same font/style as the SS design, but itsounds like you have lots on your plate already jarhead, haha.
Old Sep 9, 2009 | 03:11 PM
Photobucket
post a straight on shot of the RS for me to scan in the font your looking for.
Old Sep 9, 2009 | 03:39 PM
nemesis's Avatar
2009 Monte Of The Year
did you get my pm. i got some interest from the grand prix members for the lit up mat and they asking question that i can't answer. need you to register
Old Sep 9, 2009 | 04:46 PM
here's the RS badge. These are pics I already had. Let me know if you need bigger ones
Attached Thumbnails 1st mcf member to receive jarheadbobandmax trunk mat-rsbadge.jpg   1st mcf member to receive jarheadbobandmax trunk mat-mymonte-027.jpg
