Wheel bearings
RE: Wheel bearings
Smoothness of a ride is determined by shocks and struts, and handling is the sway bars and suspension links. A bad bearing would simply cause a loud highpitch squeal, and might eventually start to lock up on you. If you think it's bad, you can replace one for 140 bucks. These are known for failure on the FWD models.
msnyder1112
01-16-2012 11:09 AM
