Resetting Change Oil light without factory radio
Old 08-09-2008, 11:45 PM
lu9103's Avatar
Default Resetting Change Oil light without factory radio
I got my oil change about 3 weeks ago at a local Jiffy Lube, and now the message center on my cluster is showing: "Change Engine Oil" I think that they didn't reset the oil. Another reason whyI can't do it my self is because I have an aftermarket radio. Any suggenstions???? By the way it go'saway 60 seconds after the car has been on and never comes on until I turn off and then on the car.
Old 08-10-2008, 07:45 AM
Default RE: Change Engine Oil
this might sound crazy but if you turn the key to the"ON" position but dont turnthe car on and press the gas pedal 3 times realeasing it between each one for about a second and on the third one hold it down for about 3-4 seconds and then turn the key to the off position. then just turn you car on and it should go away.
Old 08-10-2008, 10:17 AM
LOL Luke LOL
It does sound really crazy
Only in a Chevy LOL
but
It Works
LOL
I wonder who at GM devised this method, and what
type of drugs they were doing.LSD
LOL
Old 08-10-2008, 05:41 PM
lu9103's Avatar
thank you so much!!!!!! It worked, thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-10-2008, 06:32 PM
No problem thats why we are here, i didnt believe the first time i heard it till i tried it
Old 09-26-2010, 12:19 AM
thanks for that cuz i couldnt figure out how to turn that off.
Old 06-08-2011, 01:10 AM
Will that work for the tire pressure and all the other lights? (except check engine)
Old 06-08-2011, 08:24 AM
03SSLE's Avatar
The Search feature at the top of the page will reveal a wealth of information. A seperate thread about your problem would also yield more replies. To reset the tire monitor turn the key to ACC or ON, then turn your parking lights on/off 3 times in a row.
Old 02-22-2012, 06:48 PM
I have an 03 and also an aftermarket radio and I have tried this a million times, but the things still will not shut off. Any other ideas?
Old 02-23-2012, 08:28 AM
You either aren't putting the gas pedal all the way down and all the way up, or you are doing it too slow.
Quick Reply: Resetting Change Oil light without factory radio
