'05 LT - No Heat
Old 12-24-2009, 09:57 AM
saigashooter's Avatar
Default '05 LT - No Heat
So i got in the car this morning to find out that I no longer have heat. I pushed the temp controls all the way up, flipped the selector to defrost/feet and then turned the fan on only to have nothing happen.
The fan had been making a light clicking the past couple days, and now it seems to have died. How do I go about replacing the fan/blower motor?
Old 12-28-2009, 07:43 AM
Got it resolved, for future reference, here e is a procedure on how to change it.
The blower motor is under the glove box.
To access it, remove the panel by squeezing the clips then pull the panel down.
Then use a 7/32 socket to remove the 3 zinc bolts holding the unit in place.
After the unit is free rotate it to access the power plug, and unplug it.
Reinstall is the reverse. Be careful, the bolts break very easily.
mymonte
11-22-2006 10:50 PM
spike_monte
11-22-2006 10:47 PM
CuttyKev
10-02-2006 10:26 PM
USELESS
05-01-2006 09:34 PM
mcarloss04
11-21-2005 11:38 AM
Quick Reply: '05 LT - No Heat
