low brake fluid/brake/trac loc lights
Old 10-09-2013, 09:32 PM
hotrodharley's Avatar
Default low brake fluid/brake/trac loc lights
here is back history;;had no lights on dash on but brake pads wore down to steel[had to wait till got cash]i replaced frt brake pads and rotors;;brakes are great now but about a week after i did this my "low brake fluid" "brake" and "trac loc off" lights all came on and stays on..brake m/c is full;;;why did these all come on after i fixed brakes and how do i get them off???[tried pushing trac button down by shifter but with no change]
this is a 04 monte ss
Old 10-09-2013, 10:15 PM
Could be wiring, or a sensor. Here is a link to a post that had similar issues that your having. https://montecarloforum.com/forum/ge...-please-43525/
Old 10-11-2013, 07:13 AM
Im having the same issue, those "idiot" lights only come on when I hit the gas pedal a little harder than usual, eventually they go off except the Trac Off light. if I shut off the car and restart it its all back to normal. over the summer I changed out the Ignition switch because of a similar issue from the A/C blower motor and resistor.
hotrodharley
11-15-2013 11:37 AM
Jerry Barao
01-12-2013 07:54 AM
ladagosta
08-24-2012 09:54 AM
Monteimpala
03-08-2012 02:32 PM
heartbeat
01-14-2012 10:47 PM
Quick Reply: low brake fluid/brake/trac loc lights
