78 monte fuel delivery
Old 06-30-2013, 03:22 AM
keith miller's Avatar
Default 78 monte fuel delivery
apologize in advance for the long post. 78 Monte, 305. not getting fuel to carb. replaced mechanical pump, and also went with an aftermarket electric pump. Can blow through thye supply line, not clogged. fuel will return through line, and after connecting supply to pump, priming carb, will start and run for about 5 minutes. then need to do the same again, run for another 5 minutes. Any help would be appreciated
ReaperSS
08-29-2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
01-26-2014 05:54 PM
robknight13607
03-20-2013 09:14 AM
MJClemm
03-18-2013 07:10 PM
Quick Reply: 78 monte fuel delivery
