New to me 02 SS
New to me 02 SS
Hey guys, I just bought my first bowtie car yesterday and im loving it. However there is a weird squeaking noise coming from the drivers side front end when I go over bumps. It happens at high or low speed and sounds like it may be coming from the struts or engine mounts.
Im heading back to the dealer Monday to have them take a look and I want to have a better idea of what to expect.
RE: New to me 02 SS
inter mediate steering shaft needs greased or replaced iss this isvery common in this year and model of car.having the same problem now.this is the 3 time i had to have this done. from what you saying this could be your problem
RE: New to me 02 SS
Got the Monte back from the dealer and it was the Intermediate Steering Shaft. Now my car smells like they set of a WD-40 bug bomb. I hope it clears up soon because I was light headed when I got home.
RE: New to me 02 SS
The squeaking sound is back!!!!! I guess the WD-40 dried up. Im pretty sure its the drivers side strut or the rubber boot. Either way its freaking annoying to hear every time i go over a bump or dip in the road.
RE: New to me 02 SS
Check out this thread: https://montecarloforum.com/m_50522/mpage_1/key_/tm.htm
Although the link to the write-up over at mymonte.com isn't working anymore and I tried to do a search over there but their search function is worse than ours. Maybe someone that frequents the mymonte forum will be able to find the write-up for you. I also found several mentions of a new part with a nylon bushing that fixes the problem...
Found this:
http://mymonte.com/discussion/index....steering+shaft
And this:
Hope that helps
Found this:
And this:
Hope that helps
