A Couple Of Questions
Old 07-09-2008, 09:56 PM
Brinksta's Avatar
Default A Couple Of Questions
1. When I turn off the car and take the key out, the left parking light stays on until I start the car and push stuff.?
2. The tire guage is reading differently then the handheld guage I have, whats wrong?
Old 07-09-2008, 10:07 PM
Brinksta's Avatar
Default RE: A Couple Of Questions
Another guestion for you. Tommorow will be the first gass fillup since i bought the car, will putting premium in it clean it out?
Old 07-09-2008, 10:16 PM
Cowboy6622's Avatar
oen of your gauges is better quality than the other, and yes, the parking light stays on until the car is turned on.
if you're looking to clean it out, i'd recommend some seafoam. pick it up at an auto parts store, it comes in a white metal can with a red logo on it. but yes, premium fuel will help it.
Old 07-09-2008, 10:18 PM
Brinksta's Avatar
It has to be the computer gauges because I used two handeld ones.
How would I go about fixing it if something is wrong (I am still under warranty)
Old 07-09-2008, 10:19 PM
Brinksta's Avatar
ORIGINAL: Cowboy6622
I mean only one of them is on and it stays on after I go inside and come back out.
Old 07-10-2008, 12:48 PM
Brinksta's Avatar
Old 07-10-2008, 01:43 PM
Brinksta's Avatar
Today when i started it up it said service tire readers or something like that.
2006 monte carlo lt.
help!
Old 07-10-2008, 02:47 PM
You probably have to get the TPMS serviced. Tire Pressure Monitor System.
It is a known issue with 06-07's usually a quick fix they callibrate the tire sensor that is causing the issue and off you go. Worst case they replace system components. Also I think there was a software upgrade for the system so that might be it as well. All is covered under warranty.
The parking light issue not sure what you mean, maybe I am just dumb. LOL
Did you check if the Right parking light is functional, maybe they both should be on but the right is the one with the issue.
I would seafoam it. No need for premium.
I had an 06 LT before the SS.
Old 07-10-2008, 02:52 PM
Brinksta's Avatar
"Service Tire Monitor System "
Is the message I get. Is there nothing I can do on my own to fix it?
Old 07-10-2008, 03:20 PM
[align=left]dup[/align]
Quick Reply: A Couple Of Questions
