zzp suspension parts for 07 LT
hey does anybody know if these parts will work on an 07 lt
ZZP Strut tower braces billet dogbones http://www.zzperformance.com/grand_p...=815&catid=138 gr2 struts http://www.zzperformance.com/grand_p...=524&catid=138 anti pogo washers http://www.zzperformance.com/grand_p...=403&catid=138 sway bars http://www.zzperformance.com/grand_p...=571&catid=138 if anyone has installed or or knows how these fit let me know what you think thanks |
The Strut Tower braces do not fit on the 06/07 Monte V6's...
The Billet Dog bones, and GR2 struts SHOULD fit, but i'm not 100% sure... |
get the GMPP strut braces with don rome brackets
i'm thinkin the sway bars are the same as the GMPP sway bars which do fit our cars. there are similar threads that talk about this too so it would help to check them also. i don't have the PN's on me now for the STB's and sway bars since i'm at work right now but let me know if you need them |
thanks ive seen you pics and it looks clean i wasnt sure what the stb looks like. is ti just a steel bar or does it have the two fingers on both sides cause if thats the case i would asume it would bolt upwith little reeming. i also work at a machine shop so that wouldnt be an issue. ya but if you would like to make some brackets or send the template that would be sweet. also under the hood by the mounts there is a few wires do you have to relocate those looks like they would be in the way.
pm sent to you mak330
