Why does one front tire stick out farther than the other?
I have issues with my front wheels, i didnt notice this until recently...my front passenger wheel sticks out like a inch farther than the driver side wheel.
Does this mean i need a alignment? Does anyone else have this problem? :confused::mad::nono: This problem is driving me nutts!! |
Alignment issues or something in suspension is bent
Originally Posted by HIxArsenaL
(Post 620778)
(Post 620889)
Can you post a Photo? of the front might help with the ???????????
I think i found the solution, i have a bad outer tie rod and makes my toe bad. |
What part of the tire sticks out?
Top or bottom of the wheel? front or back of the wheel? Top or bottom indicates a camber concern, front or rear of the tire indicates a Toe concern. Does the car pull? steering wheel off center to the left or right? |
Originally Posted by A05C
(Post 620908)
yea, It could have a bent tie rod end or the inner tie rod end could be loose. Quick way to check them is jack that side up, and wiggle the wheel/tire left and right and up and down.
Toe being out will eat a pair of tires very quickly |
(Post 621095)
I saw a 2000-2002 MC ss in Decatur AL at the corner of 6th and 8th. Something was bent, looked to be a strut issue as the top of the tire was way out and the bottom of the tire was way in... massive camber issue. Car has not moved recently.... It was the same color as mine.
Originally Posted by hillbillywizard
(Post 621202)
