6th Gen ('00-'05): Dual Brake Calipers
They do not exist for this platform. If you're serious about one, you should go to an engineering / fab shop. It's not difficult to design / build, but it would have to be a custom designed one off and will likely be fairly expensive. I'd be suprised if you could do the setup for under a grand.
Just curious, why a hydro ebrake? I get it on a RWD drift car, but I don't see the use on a FWD car.
For me it would be half function, half looks. The function would be for drag racing. Locking up the rear wheels for the burnout, and where I'll mount the two step button. The looks half is it'll be a nice addition to the "race car" look I want. (roll cage, bucket seats, harness, etc.)
Before you spend a butt ton of money on useless add ons for drag racing, I'd strongly suggest getting engine/trans built and actually run it. If you're really running it, you'll have plenty to spend your money on between tires and trans rebuilds.
There is one 'race car look' mod I would suggest, and that's gutting the car. Take out all of the unnecessary stuff - radio, AC, backseats, etc will help it go faster for drag racing. The side benefit is that it'll also help the trans stay alive longer too.
I'd also reccomend against doing 'race car stuff' for looks, especially on a street car. I'm especially against a roll cage on the street ever. You get in a serious wreck and smash your bare head on that steel tube and it's over. Unless you plan on driving to the store with your helmet on....
I've already removed the back seat and carpeting. When I find the time, I plan on removing the rest of the carpet in the trunk, and scraping off the sound deadening, to prep the interior for paint. I will probably order an AC delete from zzp, since my AC doesn't work anyway.
The factory ebrake, if properly functioning, will lock the rear wheels 100%. If your problem is dragging the locked wheels, then a hydro brake won't help that.
I just might do that. I really like the safety of a roll cage, regardless of where the cars driven. Cause you can see tons of videos of people who aren't even driving fast or recklessly, just getting hit, and their vehicle rolls over, crushing the cabin.
Sure it'll keep the roof intact, but if you've rolled it that hard to smash the roof in, you WILL smack your head on the bar, and you will die. This has been proven numerous times - cages are for track cars only.
Just fix the ebrake. To me that sounds like saying your engine doesn't work well, so you're going to swap another engine onto the rear wheels.
The only way it is safe to drive with a full cage is with a helmet. If you're going to wear your helmet driving on the street to the grocery store, then that's fine. But driving with a cage and no helmet is MORE DANGEROUS.
I'd think this would kinda be a detractor from looks having a drift brake setup on a FWD car that can't actually drift, but of course that's just personal opinion.
I'm not disputing the fact that using a cage without a helmet is dangerous. I know that it is. A roll cage is just something I want in the vehicle, for safety, and looks.
Like the above, I'd also personally think this would be a big detractor to looks. I'd imagine you'd get a lot of laughs climbing out of a caged 11 or 12 second street car with your helmet on at Walmart or something.
If it's mostly for race car looks anyways, I'd probably just do a chute instead. A lot more visual impact without being such a giant pain for street driving.
Yeah, a chute would look nice as well. Thanks for your input. I really like coming to this forum and just talking through some of my ideas with the people here. It helps refine the ideas I have, and gives me information I might not have found otherwise.
Timothy Jarvis
39
10-02-2015 09:15 AM
