-   Tires/Rims/Suspension (https://montecarloforum.com/forum/tires-rims-suspension-16/)
-   -   Trailing arm question (https://montecarloforum.com/forum/tires-rims-suspension-16/trailing-arm-question-21952/)
crzy1051 Jul 11, 2010 03:51 PM
Recently my Left trailing arm snapped in half, i have recieved the new part but when removing the old one the arm-to-chassis bolt was stripped and not able to be used again. Do anyone know where i can order a new one to get shipped to my home?
thumpingetocar06 Jul 11, 2010 05:08 PM
You probably will have to go right to your local GM shop. and they should be able to help you and send the part right to your house
monte carlo 3831 Jul 11, 2010 05:25 PM
I checked out this place, but had no real idea what you needed, maybe you can a part # and then go to your local GM shop.
http://www.gmpartsdirect.com/
Pure2sin Jul 11, 2010 11:56 PM
Are you talking about the bolt that goes into the bracket or the bolt that connects to the knuckle? The bracket bolts and arm to bracket bolts can be bought at GMpartsdirect.com, the bolt from the knuckle to the arm can be found there too.
