Tire Pressure Sensor
what PSI do your tires have to drain to before the Tire Pressure Sensor throws a message? for ex, i have standard 225/60/r16 with max load 44 PSI, i usually keep them around 35-37psi.
The sensors work from the wheel hub assembly sensor. It detects when one tire is rotating at a different speed than the others, so it typically is when one tire is 5 pounds lower than the other 3.
Your max load of 44PSI is not a fill-to recommendation. I would lower the PSI to what the car requests on the door jam, which is around 32. (unless you are wearing out the sides faster than the middle from under-inflation) :thumbsup: |
(Post 655299)
So yesterday my low tire pressure message came up. And on my way to work this am my service traction light came on to and shut my traction off. Any ideas? Okay to drive?
Originally Posted by bowtiebandit23
(Post 655462)
(Post 655481)
Okay to drive (make sure your tire pressures are good), probably have a wheel hub starting to go out, or the wiring to one is bad
Your abs wheel speed sensor could also be a broken wire, I had to replace my wires a couple years ago as the wires weren't worth soldering and fixing as it was just going to be a matter of time. You can buy replacements on e bay for around $20, they get brittle with age and break up along the frame where they are routed so you unfortunately have to trace the wires back to find the break. The water will also set the sensors off if it gets in.
