Thanks...was wondering what I did to upset the guy??? Will continue to search for original replacement wheels but that looks like it may be a tough mission!! Car is so nice I hate to mess with the original look!!
:rolleyes:...It's also on my Search List, and I'm sure several member's will be on the look `out for replacement Rim's for You & will post or PM you `if they find them. Good Luck & Don't Give `Up
Wish you and readers a Happy `Day from `Space : ) |
CHeck out the below links, and sometimes `if you call the companies, they might suggest a place that has what you are looking for...Good Luck http://www.finishlinewheels.com/CHEVY/MONTE+CARLO/2004/ and http://www.autopartswarehouse.com/se...=&N=0&Ntt=Rims |
Check ebay, oemwheels or something like that was cheap and they hold up great *knock on wood*
You can also try this site out. They are OEM wheels only. It were I am getting mine.
http://www.oewheelsllc.com/ Hope this helps. |
Intimidator wheels for sale.
I have an auction up for 4 more days on e-bay for (5) original 2004 Intimidator wheels. They are up for auction because I had the same problem of the insides peeling, yet the outside faces look great. I replaced them on the car with aftermarket alloys for about $125 each.
I did experiment with removing the loose plating and then taking a wire wheel brush via drill to clean the insides up. I then painted them with silver Rustoleum. Cheap fix, works great. Got to watch out for the valve stem area though... if those holes get too bad, then the whole wheel is only good for making a overweight wall clock. |
