Spring ideas
Ok, heres the basics of my "handles like a rollerskate" 78 Monte. Poly bushings all around, boxed stock rear control arms, haven't decided on shocks yet,larger sway bar front, find one for the rear, same width wheels and tires all the way around(haven't decided what size yet). Now heres where I get stuck. Should I go with factory SS springs front and rear, or go with heavy duty ones I found in my MOOG catalog? HELP!!
Cheers! Stacey |
RE: Spring ideas
go with the better ones for the best ride
RE: Spring ideas
the heavy duty ones are going to be a stiffer ride, you want to make sure you get the rightengine size ones and weather its with or without a/c
and its best to get the ones that say variabe rate :) those will give you the best ride :) |
