Raise front end
I have a 77 Monte and want to raise the front end an inch or two so it sits level. I like that look. Has anyone done this and what's the easiset way?
Hi WarFighter,
I'm not sure, but check out the below & see if it helps... Also, check back on your thread to see what our knowledgeable member's posts on your question :thumbsup: How to lift coil spring cars to make front end higher? | The H.A.M ... www.jalopyjournal.com › ... › The Hokey Ass Message Board Mar 26, 2013 - 19 posts - 16 authors ... coil spring front end and control arms but want to give it say an inch, ... Chev pickup truck spindles will fit, and raise the car a couple of inches. ► 3:41► 3:41 www.youtube.com/watch?v=dQ38seFkiPg Nov 29, 2011 - Uploaded by Reverse Gear A quick off the car look at how to raise the front end of your derby car. No extra parts needed. Top 10 Ways to Lower and Lift Your Car or Truck ... - Auto auto.howstuffworks.com/under.../10-ways-to-lower-and-lift-vehicle.htm Lowering a car by adjusting the spring length or placement is a popular and ... Most are affordable, and cost less than $50, but there are higher-end springs that ... Front Coil Spring Spacer - Global West Suspension www.globalwest.net/1106.html $22.87 |
Thank you Space for the info!!! I appreciate it!!!
