Lug Stud Help
Ok so if these fit my 05 monte... They do, ive triple checked..
https://www.dormanproducts.com/p-789...rigin=oesearch Then so would these, correct? https://www.ebay.com/itm/10x-Syun-60...-/182633577538 Im 99.9 percent sure ive correctly matched the knurl size.. And shoulder length. Pls tell me im right..? |
Yes ,you are correct they will fit in the hub . The only issue you might run into is the length. Nothing exciting but you might have too loosen the hub from the spindle to get the longer studs installed. Good luck
If you're looking for extended studs, you should take a look at ARP. I dunno about trusting some random company with a safety critical item like that.
9mm difference in length might stop a capped nut from tightening a wheel
Also, Dorman measures the length in the entire bolt, end-to-end. That ebay listing is measuring 60mm on the thread alone. Those studs are going to be pretty long |
| All times are GMT -5. The time now is 04:23 AM. |
