How to restore polished factory alloy wheels?
1 Attachment(s)
Hello guys,
I have 2004 Monte Carlo with factory alloy wheels with polished board and center star. With the years past, the coat started to chip off. See it on the pictures. I know, if I sand blast them, it will ruin the polish. Is there some chemical that would dissolve/remove the coat? Then, what is the right coat for them? I talked to local wheels guys, all of them said, neither clear powder nor lacquer will stay long on polished parts. What is the correct way to restore them? I am not in USA which makes thinks worst http://www.hotrodders.com/forum/imag...lies/smile.gif Thanks for the help, Ivo |
I have this same wheel on my Monte. Here is what I used. Finger nail polish remover or Acetone. Scrub it with that, I used a Microfiber cloth and it worked well. Tough areas a 3M pad. once you get the desired look. Clear Coat them again and you should be good until the next time. :thumbsup:
