-   Tires/Rims/Suspension (https://montecarloforum.com/forum/tires-rims-suspension-16/)
-   -   G Body Rear Tire Size? (https://montecarloforum.com/forum/tires-rims-suspension-16/g-body-rear-tire-size-2399/)
KingSize Oct 7, 2006 10:13 AM
What is the widest tire you can fit under the stock tubs in an '87 SS? I think I had 245's on my '84, but would like to at least tuck some 255's under there. I need wider tires in the rear (225's now), but want to keep from rubbing and be able to keep the tire tucked inside the fender wells.
It is lowered 2" BTW.
85_SS Oct 8, 2006 01:33 AM
RE: G Body Rear Tire Size?
It will depend on what wheels/backspacing you are using, but 275 (60 or 50 series) tires can fit no problem. I've seen both on stock wheels, but that is getting a little wide for a 7" wheel. I have 245/60's all around on my Monte with a 3/2" drop.
rj Oct 22, 2006 09:28 PM
I'd like a bit more tire under my '86 LS. I did kind of a tire poll at the 2005 Monte Nats in Decatur, IL.
Saw a lot of 255 and 275 sizes with a few 295s. But like was posted it depends on the wheel and backspacing used.
KingSize Oct 23, 2006 12:00 PM
I currently have 18X8 in the front and 20X8 in the rear. I've got the perfect stance with that combination, and a 2" drop. The problem is I want to go wider now in the rear. I have looked on Ebay, but I would have to buy a whole set of wheels. I want to keep the ones I have and just get wider ones for the back. They make 20X9.5, which is what I would like to run. But selling my two and buying just two is going to be hard to do. Unless of course money isn't an issue, which in fact it is. This sucks.
88ss408 Nov 23, 2006 07:30 PM
i got 295 on my 88 right now on a 10 inch rim and i am riding on caprice coil spring for about a 2inch lift and no rubbing can you say hello for traction
85T5MCSS Nov 23, 2006 08:19 PM
255-45-17 all around with no issues to really speak of. I do rub the rubber brake up front when the wheel is at full lock because I don't have steering stops and the back is close to the fram but no rub. I run a 17x8 with 4.00" backspace all around.
ziggy 87 Nov 29, 2006 07:20 PM
My 87 SS is lowered 2" and I have 15x8 wheels with 3 1/2" backspacing. I currently have BFG radial T/A's size 295/50/15, they are 9 1/2" wide and I can fit a finger between the tire and frame. I don't have any problems running this size.
Jay Hallauer Aug 31, 2015 11:18 AM
Question
i have a 1978 Chevy Malibu G body- im looking at a tire dimension of 245/50r20 front & 2/ 265/50r20 in the back. Is this do-able?
Missy Gray Jun 1, 2018 04:06 PM
I have an 84 MC
I have an 84 MC base no,SS. What diff size tires can I put on my car
steven-taylor Nov 4, 2018 09:04 AM
Looking for Advice!
I owned 295 on my 88 right now, waiting to hear from you guys what kind of dimension tires I can select for this one.
