fwd lift kit??
Old Oct 25, 2009 | 07:45 PM
STL_CHeVY_RiDeR's Avatar
Default fwd lift kit??
right now ive got 22's on 245/30/22 tires.... and ive got the lifters in my springs which gives me about 1-2 inches but im tryna go higher so i can do a thicker tire on the 2's 265 maybe or i might do 24's this next summer..
BUT i dont like the fact that the strut plates were rubbing in the back when i first put the rims on and we ended up beating the strut plate upwards to fix that.. not that it rides any different or is giving me any problems but i like to do things the right way
anybody have any experience or knowledge with this kit? is it worth it? a local shop is tryin to sell it to me for about $850 they say its a 3" lift with custom front and rear struts
ill appreciate any feedback
Old Oct 26, 2009 | 04:52 PM
SolowSS's Avatar
Just call me Dubs
I thought about getting those before I had mine made it takes the guess work outta it.All you do is take factory struts out and put those in.But question for you is it just the struts in the kit or does it come with anything else cause with a 3 inch kit unless you add a slip yoke to your drive shaft your going to bind alot probably to the point you won't be able to drive your car or what I did was heat up the spring to compress them down at bit so my car wouldn't be so high but I still had the clearance I needed between the wheel and spring purch
Old Oct 27, 2009 | 11:21 PM
good lookin out, they claim the binding isnt a possibility but definately something ima have to look further into
how many inches up where u sittin in that pic thats in your sig
Old Oct 28, 2009 | 04:44 PM
SolowSS's Avatar
Just call me Dubs
that's 2.5 inches
bmcd06
May 12, 2009 09:58 AM
Xcato
Nov 9, 2008 09:15 AM
vita
Aug 23, 2008 09:53 PM
atoc
Jul 30, 2007 01:44 PM
JK88SS
May 6, 2007 11:14 PM
