Drag Slicks
Old Feb 24, 2013 | 08:58 PM
Monte SSV's Avatar
Enzo - that would be great if you could let me know.
Meanshwamonte - I have Wilwood calipers and rotors on all four corners and the only wheel that fits over them are my stock 18's
Old Feb 24, 2013 | 10:40 PM
TheMonteMan's Avatar
i dont know what kind of power your making and im going to assume that your car is fwd, but there are cars that run insane times on a drag radial. granted these are huge tire, all out back halfed cars, but the point is how fast can you possibly be trying to go that a drag radial isnt hooking up. at that point id be looking into suspension and trying to limit weight transfer. run the widest dr with the most sidewall you can get.
Old Feb 25, 2013 | 07:49 AM
Monte SSV's Avatar
Monteman: I am running P285R40/18 for the strip but turning is an issue with some rubbing. But at the track I can deal with that. I want to replace my P255R45/18's I have on it that are stock tires with DR's for street/show purposes where turning is now an issue because I do not want to have any rubbing issues especially on the street.
The car is FWD with 814 FWHP.
Old Feb 25, 2013 | 08:50 AM
Could u get away with running a 245 instead of a 255? Not much difference in tread with 9.0 vs 9.10
MH Racemaster Drag Tires - 245/40R18 Radial Drag Rear - Radial Drag
Old Feb 25, 2013 | 12:24 PM
Monte SSV's Avatar
Definitely will check it out. Thanks
Old Feb 26, 2013 | 12:43 PM
285 is certainly a wide tire. 275 is what the gxp guys run on there cars and have very little rub at full turn. is this a turbo car? and what kind of suspension work is done to it?
Old Feb 26, 2013 | 07:45 PM
Enzo354's Avatar
STILL SLOW
This is the silver 800 hp Monte. There are a few suspension mods done
Old Feb 26, 2013 | 07:47 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
^^^This...
LOL.
I was looking today too and I couldn't find anything close.
Old Feb 26, 2013 | 08:24 PM
This is the Monte the forum member owns and is wanting to source out slicks for. It's the only 6th / 7th gen running the huge Willwood rotors and calipers. There has been an extensive amount of suspension work completed. Probably nothing left un-done in all reality with the suspension.
Old Feb 26, 2013 | 09:49 PM
Looks slow Sam, real slow
